2000 Chrysler LHS Exhaust is still smoking when I turn off
2000 CHRYSLER LHS
111,700 MILES • 6 CYL • FWD • AUTOMATIC
MRTANNER82
Last night I noticed my car running like it was almost missing a few cylinders. When I got out of the car at my house I noticed it was white smoking alot and that the smoke continued out of the exhaust for a minute after I turned the car off? What could this be?
Oct 21, 2008 at 3:37 AM
  • 110,240 POSTS
Hi:
If you took a short trip, condinsation can cause a white steam. However, a bad head gasket can cause white smoke by allowing coolant into the combustion chamber. Check oil for water contamination and the radiator (when cold) for oil.
Also, you may want to have a compression test done on the car to see if everything is wrong.
Let me know if you have any other questions, let me know.
I hope this helps,
Oct 26, 2008 at 8:00 AM
