1995 Chrysler LHS no power to one of the fuel injector wiri
1995 CHRYSLER LHS
15,700 MILES • 6 CYL • FWD • AUTOMATIC
BROBILL
A friend of mine and myself were able to isolate the problem with my car down to no power to a fuel injector connector. Do we need to isolate the wiring to the connector, and can we run a new set of wires from the injector to the PCM?
Oct 11, 2008 at 12:18 AM
2CARPRO JACK
  • 11,533 POSTS
The injectors are powered off the same wire to all of them, each injector is spliced in.Open theharness up to thenext injector that has power, and replace it from there. The injector is triggered by the PCM with ground, so there is no need to run a power wire anywhere but to the next working injector....... Good find BTW
Oct 11, 2008 at 1:17 AM
