1995 Chrysler LHS Gas smell
156,220 MILES • 6 CYL • FWD • AUTOMATIC
FILMORELIVE
When I first start my car it smells of gas. What could be causing that? And could that be the reason why my car gets poor gas mileage. I get about 160 miles for every half tank.
Apr 5, 2009 at 2:05 PM
CARADIODOC
  • 34,414 POSTS
Would you guess gas is leaking out? Since we can't see your car, I'd suggest you look under it to see if there's a puddle of gas and where it is. That would give us a clue as to the cause.
If there's no puddle on the ground, suspect leaking rubber o-rings in the fuel rail on the engine. That's a fire hazard.
It's only logical to assume if gas is leaking out, it's going to affect your gas mileage.
caradiodoc
Apr 7, 2009 at 12:40 AM
