1995 Chrysler Le Baron transmission removal
161,000 MILES • 6 CYL • FWD • AUTOMATIC
CHRIST1G
When the transmission is removed, does the Oil pan need to be removed? I had a trans repair done and it seems like an oil leak got alot worse afterwards.
Oct 9, 2008 at 2:33 AM
  • 110,248 POSTS
No it doesn't need removed. Is the leak at the rear of the pan? If so, chances are the rear main is the problem.
Mar 17, 2009 at 6:16 AM
