1995 Chrysler Le Baron leaking water not radiator our hoses
CHRISTIAN327
  • 6 POSTS
1995 Chrysler Le Baron 6 cyl Front Wheel Drive Automatic
leking water when engine is on
May 21, 2009 at 2:32 PM
LEGITIMATE007
  • 5,121 POSTS
what area,? it could be at the water pump, heater hoses, what area is it leaking
May 21, 2009 at 2:41 PM
CHRISTIAN327
  • 6 POSTS
its leaking under the car everywhere for about a year I drove with water jugs filling the car up every time i was going it would last untl one day it got hot and water leaking underneatrh the car and wont hold water
May 21, 2009 at 2:48 PM
LEGITIMATE007
  • 5,121 POSTS
It sounds like it is comming from a freeze plug, the way your describing it. Its still a little vague , the way you describe it. because it could be leaking from the rear and just trickle down the back and appear to look like its comming from the bottom
May 22, 2009 at 5:14 AM
