1993 Chrysler Le Baron
TONY MADUNICH
1993 Chrysler Le Baron 6 cyl
93 lebaron stalls randomly although it only happens when car is warm. Engine will sputter but usually not restart until cooled down. No engine trouble codes. Tachometer drops to zero before car stalls out completely. Sometimes tach stays at zero even when idling fine. Car always starts and runs fine when cold.
Sep 13, 2008 at 10:32 AM
  • 110,248 POSTS
Hi:
What you are describing sounds like your fuel pump is going bad. A good place to start is by having the pump pressure and volume checked.
NOTE: If this is a problem that always occurs, allow your local mechanic drive it until it shuts down and then check the fuel pressure.
Oct 4, 2008 at 4:05 PM
