1995 Chrysler Le Baron engine stalls
1995 CHRYSLER LE BARON
111,000 MILES • 6 CYL • FWD • AUTOMATIC
SIMNTUE
1995 Chry. LeBaron 3.0 stalls while driving under normal driving conditions at least once a day. It mostly happens within the first several miles. I am able to start it back up and sometimes have to wait several mins. before it will start. I have replaced the fuel filter and spark plugs. What do you suggest I look to replace next? Thanks
Aug 23, 2008 at 11:22 AM
Duplicate the problem when it happens hit it with a carb cleaner
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Aug 23, 2008 at 11:55 AM
