1991 Chrysler Le Baron Shifting
S.GUERRERO3154
  • 1991 CHRYSLER LE BARON
  • 6 CYL
  • FWD
  • 100,000 MILES
The car starts off in second gear and every now and then it will downshift into low and it wont shift out. When I start it up it is in second gear. Do you think I need to replace the transmission in this car? Or maybe replace the ECU?
http://www.2carpros.com/forum/automotive_pictures/497602_800pxChryslerLeBaronsedan_1.jpg
Tuesday, March 9th, 2010 AT 3:09 PM
  • 109,885 POSTS
Before replacing the trans, I would recommend having the trans control module (TCM) tested by a certified trans tech. It can cause this type of problem and is much cheaper to replace than a transmision.
Let me know if the check engine light has come on.
Thursday, March 11th, 2010 AT 10:07 AM
S.GUERRERO3154
Joe-
Thanks for the reply to my question.
Yes, the check engine light is on.
Take it easy,
Sam
Saturday, March 13th, 2010 AT 4:08 AM
  • 109,885 POSTS
Since the light is on, there should be a trouble code stored in the computer. It may identify where the problem is coming from. I would "guess" it is the TCM, but you need to have the computer scanned to determine if that is correct. Have it done. Most nationally recognized parts stores will do it for free, so there is no money out of pocket for you. LEt me know what code they find.
Saturday, March 13th, 2010 AT 11:54 AM
S.GUERRERO3154
Hello Joe-
Well, I replaced the TCM and still have the same problem. Now that I think back, I believe the spedomoder and the transmission quit working properly at the same time. Are these two problems related?
Thanks!
SAM
Sunday, March 14th, 2010 AT 3:35 AM
