1990 Chrysler Le Baron Speedometer Does Not Work
1990 CHRYSLER LE BARON
185,000 MILES • 6 CYL • FWD • AUTOMATIC
JSTHURMAN
I bought a LeBaron that has an electronic speedometer instead of having a cable. The Odometer, Trip Counter and Speedometer does not work. It is not a digital read but looks like a standard needle type. All of the other gauges work fine How do I get the Speedometer to work.
Oct 3, 2009 at 10:32 PM
CH112063
  • CAR REPAIR CONTRIBUTOR
  • 1,320 POSTS
The 3.0l uses a speed sensor, the 3.3l uses a trans controller and a crank and also a speed sensor, but depending on whether you have an overdrive or not is where the signal comes from. I am sure you do, so you really should use an electronic scan tool to see what is amiss. Know what I mean. I believe you have a bum speed sensor. OK Joe
Oct 5, 2009 at 10:48 AM
