1990 Chrysler Le Baron New battery n alternator. But wont h
DCPOET
  • 1990 CHRYSLER LE BARON
  • 6 CYL
  • FWD
  • 190,000 MILES
Im not sure what the problem is but I have anew battery n alternator and neither stays charged. It just started doin this! Im thinkin it a electrical problem. The car would start then slowly power down and then nothin. Any ideas or help advice?
verbalgenius@yahoo. Com
Friday, April 17th, 2009 AT 8:24 PM
Could be the computer controlled of the field generation of the alternator
Friday, April 17th, 2009 AT 8:38 PM
CARADIODOC
  • 33,916 POSTS
Measure the voltage on the two small terminals on the back of the alternator while the engine is running. 0 volts on both; look for a broken feed wire or corroded pin in a connector. Exactly the same, about 12 volts, on both; look for an open wire going to the voltage regulator in the engine computer, or a defective regulator. If one has a lower voltage, 4-10 volts typically, the alternator is working. In that case, measure the voltage on the fat wire bolted to the back of the alternator. It must be between 13.75 and 14.75 volts and the battery voltage should be the same. If the alternator voltage is higher than the battery voltage, the heavy wire is open, there's a corroded connector near the battery, or there's a high amperage fuse in the fuse box under the hood that's blown.
If you find 12 volts on one terminal and 0 volts on the other, the brushes are worn. Not likely since you have a new alternator.
These voltages come through the Automatic Shutdown relay. The engine must be running for the relay to turn on, or you can bypass the relay and make the measurements without running the engine.
Caradiodoc
Sunday, April 19th, 2009 AT 1:32 AM
