1988 Chrysler Le Baron Stall
XONNION
  • 1988 CHRYSLER LE BARON
Engine Mechanical problem
1988 Chrysler Le Baron 4 cyl Front Wheel Drive Manual
1988 LeBaron, manual transmission; Car will start, but idles rough. When I push on the gas, it chokes and tries to stall, have to feather throttle to keep engine running. Strong sulfer smell follows. When placed in gear engine stalls. Error codes are: coolant sensor voltage and AIS circut.
Thursday, July 9th, 2009 AT 8:57 PM
  • 110,055 POSTS
First, check for vacuum leaks and make sure the catylatic converter isn't plugging. If everything looks good there, replace the ambient temp sensor. Chances are it is telling the computer the wrong info and causing it to run too rich.
Let me know what you find.
Friday, October 9th, 2009 AT 5:36 PM
Related Engine Stall While Driving Content
Is it Safe to Drive Check Engine Light?
VIDEO
