1986 Chrysler Le Baron Starves and Stalls :-(
1986 CHRYSLER LE BARON
SHACKELL
1986 Chrysler Le Baron 4 cyl Two Wheel Drive Automatic
I can start it up fine but after a minute she runs really rough and feels like the engine is being choked off and eventually stalls. Error codes 13,33,54,55
13 and 33 shouldn't effect my drive ability.
54 and 5 are too vague in the haynes manual.
I've replaced the (new)'Hall effect Sensor',(new)'Cap and Rotor',(new)'Air Filter',(used at 'Pick'n'Pull')'Logic Controller with MAP Sensor'
The logic control/MAP sensor helped but it's still pretty bad.
Oct 29, 2009 at 7:41 AM
JDL
  • 16,098 POSTS
Welcome to the forum, code 13 can effect drivability, check the vacuum source. Code 54 shows turbo only, are you turbo?
Oct 29, 2009 at 8:05 AM
SHACKELL
Yep this is a 2.2L 4cyl turbo. My haynes manual says code 13 is A/C clutch relay...what vacuum source?
Should I try a 'NEW' MAP sensor?
Oct 30, 2009 at 1:30 AM
JDL
  • 16,098 POSTS
My info says code 13 is the map sensor, check vacuum to the map sensor.
Oct 30, 2009 at 2:48 AM
