1993 Chrysler Le Baron
1993 CHRYSLER LE BARON
DEMONDC1
Engine Mechanical problem
1993 Chrysler Le Baron 6 cyl Two Wheel Drive Automatic
what is the map sensor and how can i fix it
Oct 18, 2009 at 4:48 PM
CH112063
  • 1,320 POSTS
The manifold absolute pressure sensor is used for fuel and spark control by the engine computer(PCM). It is plastic, electronic, and is connected electrically and by a vacuum hose to the engine intake manifold. Two body styles in 93. It is black and mounts on the right side shock tower or firewall. Replace it with a new good one. You can fix the old one and keep it as a spare. It is plastic and glued together. I don't recommend trying to fix it. ok
Oct 24, 2009 at 11:12 AM
