1986 Chrysler Le Baron engine power loss
1986 CHRYSLER LE BARON
8,700 MILES • 6 CYL • 2WD • AUTOMATIC
PITCHER
the instrument panel reads power loss
i am starting the engine and give gas
but the engine will die out.
Aug 9, 2009 at 1:39 PM
BILLYMAC
  • 2,204 POSTS
Hi, well this could be many things.
first check fuel pressure
then check cap rotor and pick up
next check convertor for restrictions.
you don,t mention a check engine light. if it is on scan for codes. sounds like a fuel pump or filter prob but these things have to be checked to verify this. good luck billymac
Aug 9, 2009 at 1:49 PM
