2002 Chrysler Intrepid Won't start
2002 CHRYSLER INTREPID
253,000 MILES • 6 CYL • FWD • AUTOMATIC
SONJA TYSON
Hi ,
My car won't start. If i spray fuel into the air intake system the car will start and run. Have replcaed fuel pump and have lots of PSI , lots of power everywhere else. Seems like it's not getting the fuel. What could cause my car not to run??
Aug 16, 2010 at 11:58 AM
Check if the injectors are pulsing providing fuel to the cylinders and also recheck the fuel pressure if its within specs
Aug 16, 2010 at 12:10 PM
SONJA TYSON
[quote:9e23dd3ea1="rasmataz"]Check if the injectors are pulsing providing fuel to the cylinders and also recheck the fuel pressure if its within specs[/quote:9e23dd3ea1]
I checked to see if there was power in the injectors with a test light and there is power there. How else would i check the injectors?
Aug 16, 2010 at 1:21 PM
If there's power to the injectors and not pulsing-check the computer ground drivers circuit
Aug 16, 2010 at 8:57 PM
