1997 Chrysler Grand Voyager Rough Idle
CLIPPYCLIVE
Hi, I have a 1997 3.3ltr chrysler grand voyager, when i parked it last night it was ok. this morning the engine is running rough, engine cuts out when i stop at stop signs, transmission drops out when cornering. checked fluid everything okay.
thanks in advance for taking the time to answer this query.
Clive
Apr 30, 2007 at 10:04 PM
2CARPRO JACK
  • 11,533 POSTS
Have it scanned for codes.Have you looked around under the hood? Are there rats where you live? Since it was ok when you parked, look to see if any vermin has chewed up any wiring. Otherwise it may need to go in and be scanned to give us a place to start
May 1, 2007 at 1:10 AM
Suggested Repair
Scan the vehicle for diagnostic trouble codes and inspect under the hood for rodent-chewed wiring, since the symptoms appeared overnight.
Conversation Summary
The owner of a 1997 Chrysler Grand Voyager with a 3.3L engine reported a rough-running engine, stalling at stop signs, and the transmission dropping out while cornering after the van had been fine the night before. Fluid level was checked and found okay. The expert recommended scanning for codes and inspecting under the hood for wiring chewed by rodents or other vermin.
