2002 Chrysler Grand Voyager
MICKYP1964
  • 2002 CHRYSLER GRAND VOYAGER
Engine Mechanical problem
2002 Chrysler Grand Voyager Two Wheel Drive Manual 120000 miles
can you tell me if the cam belt snaps does it do any damage to engine
Sunday, October 18th, 2009 AT 6:20 AM
BMRFIXIT
  • 19,053 POSTS
What do you have for engine
chances is very high if timing belt brake for a bent valve
I have seen it where some survived best bet is to install new timing belt and try
good luck
Sunday, October 18th, 2009 AT 7:40 AM
CARADIODOC
  • 34,373 POSTS
Never worked on a 4 cylinder but I think BMRFIXIT is right about the bent valves.
3.3 / 3.8L V-6 uses a timing chain. 3.0L engine is not an interference engine. A broken belt will not cause valve problems on that engine.
Caradiodoc
Tuesday, November 10th, 2009 AT 1:59 AM
