2000 Chysler Grand Voyager oil leak
2000 CHRYSLER GRAND VOYAGER
124,000 MILES • 6 CYL • 2WD • AUTOMATIC
DENNISJ17
its leaking oil bad i had just changed the oil pan gasket and it didnt leak for a day wheres my leak?
Jul 1, 2008 at 4:38 PM
  • 110,240 POSTS
Hi:
If you replaced the oil pan and it didn't leak for a day and then started, you need to recheck your work. It's possible that you over tightened the pan and caused it to split. Did you remove the oil filter? Could you have double gasketed the new filter when you replaced it? Is it leaking from the front of rear of the oil pan? Is the oil coming from down low or could it be a valve cover gasket?
Oct 8, 2008 at 9:59 AM
