2005 Chrysler Crossfire Air Filter
27,505 MILES • 6 CYL • FWD • AUTOMATIC
LHENDERSON
How do you get to the air filter in my crossfire to change it.
Aug 27, 2009 at 9:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The engine air filters come two to a box. The cover on the engine removes easily. First the two air intake pipes slide off, then the cover unsnaps from the engine. The two air filters are housed in separate compartments that are secured by Torx bolts. Simply open each panel and remove the old filter, replacing the new filter in its place. Once done, reassemble the compartments and replace the engine cover making sure all three snaps are secure.
Aug 27, 2009 at 1:09 PM
