2005 Chrysler Crossfire oil change
2005 CHRYSLER CROSSFIRE
15,000 MILES • 6 CYL • 2WD • MANUAL
RUDYROSS
We only put about 5000 (easy) miles a year on our Crossfire but it's a daily driver. Our problem is when do an oil change. Last year I put in Amsoil 0w30 and a Wix filter. The container says it is good for up to 35000 miles, but the attendant said to get the oil changed every year.The oil was nearly $10 a quart and takes 9 quarts. Please give me some guidance. Thank you.
Oct 17, 2008 at 2:53 AM
  • 110,244 POSTS
Hi:
You should change oil every 3K miles or once a year, what ever comes first.
As far as all oils, they don't wear out. They get dirty. Almost all oils today have a detergent in them. Thus, they are made to clean. After about 3K the detergent breaks down and stops doing its job. That is why most recommend changing it at 3K (and not 35K).
joe
Mar 16, 2009 at 8:39 AM
SOS032781
it's recommended to change the oil every 3-5k/year,or once a year. it's oil is there to clean the engine, so it's essential to have an oil change every year.
Satisfaction is derived from a job well done.
Jul 20, 2009 at 7:56 AM
