1999 Chrysler Concorde Running Hot
PGHMARK
I have a "99" chrysler concorde, it has started to run "hot" no check engine light came on, the fans work with the ac on, but also come on when the car is starting to overheat. they do not seem to come on when they are supposed to, would this be as easy as a coolant temp sensor? it is starting to get a bit warm here and turning on the heater to cool things down is not an option anymore..
thanks
May 6, 2007 at 9:43 AM
2CARPRO JACK
  • 11,533 POSTS
Very possible it is out of range and reading wrong. If they come on , look for any obstructions in front of the radiator (plastic bags.. etc...) coolant full? leaks?
May 7, 2007 at 7:00 AM
PGHMARK
[quote:02da3d3b54="2CarPro Jack"]Very possible it is out of range and reading wrong. If they come on , look for any obstructions in front of the radiator (plastic bags.. etc...) coolant full? leaks?[/quote:02da3d3b54]
that did the job, thanks
May 13, 2007 at 6:23 AM
Suggested Repair
Check the coolant temperature sensor for an out-of-range reading, inspect the radiator front for obstructions, confirm the coolant is full, and look for leaks.
Conversation Summary
A 1999 Chrysler Concorde was running hot without a check-engine light. The cooling fans worked with the A/C and during overheating but seemed delayed otherwise. The expert suggested a faulty coolant temperature sensor and checks for radiator obstructions, low coolant, and leaks. The owner later reported that those checks resolved the problem.
