1999 Chrysler Concorde Starter Removal Fix
1999 CHRYSLER
BUGWACO1
I have a 1999 chrysler concord starter that i cannot get Out. Is their a trick t that Might Help? What Is the proceess to reeplace the Starter? I Have Spent 3 Hours trying to remove it with no succeess. Help!!!
Dec 16, 2006 at 1:49 AM
CARUNDELL
  • 602 POSTS
[quote:a8d7c2cc64="bugwaco1"]I have a 1999 chrysler concord starter that i cannot get Out. Is their a trick t that Might Help? What Is the proceess to reeplace the Starter? I Have Spent 3 Hours trying to remove it with no succeess. Help!!![/quote:a8d7c2cc64]
Hey bug!
yup, its a puzzle! the starter comes out from the rear (behind the bell housing of the trans) once everything is disconnected. You may have to give a tiny bit of "creative prying" to get it past the bell housing, bit it will come out! Let us know!
Chris
Dec 16, 2006 at 7:28 AM
Suggested Repair
Disconnect the starter, then remove it from the rear behind the transmission bell housing. A small amount of careful prying may be needed to clear the housing.
Conversation Summary
The owner of a 1999 Chrysler Concorde could not remove the starter after three hours. The expert said it is a tight fit and comes out from the rear behind the transmission bell housing once disconnected, with light prying if needed to clear the housing.
