2001 Chrysler Concorde A warning message
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
KARSAL
When I give the start the motor light indicator, keeps on, but everything looks fine.
Another problem is when I turn on the air conditionated after a while it strat to produce some smoke in the motor area.
Thank you, for your help.
Kind regards
Karsal
Feb 19, 2010 at 9:57 PM
  • 110,248 POSTS
Karsal:
If the check engine light is on, there is a trouble code stored in the computer. What I recommed is to have the computer scanned at a nationally recognized parts store. Most will do it for free. The code that is stored will identify where the problem is coming from.
As far as the smoke, check to see if there is an oil leak from the valve covers or when you see the smoke, open the hood and see if you can tell where it is coming from.
Feb 27, 2010 at 4:25 PM
KARSAL
[quote:d2fc3880f5="Jacobandnickolas"]Karsal:
Joe[/quote:d2fc3880f5]
Thank you alot for your tips, now have some others prioritys and the car is somehow forgoted, but as soon as I can deal with such problem I will let you know.
Once again thank you alot for you kind help
Kind regards
Karsal
Mar 2, 2010 at 6:08 AM
  • 110,248 POSTS
That's fine. Let me know what you find when you get the chance.
Mar 2, 2010 at 10:30 PM
