2000 Chrysler Concorde engine maintenance
80,000 MILES • 6 CYL • FWD • AUTOMATIC
BOB KAY
I am nearing the mileage to replace the timing belt, plug wires and plugs also, think my front crankshaft seal is leaking. Are there any other components I should consider replacing inconjunction with this level work and mileage?
Dec 23, 2007 at 6:52 AM
  • 31,937 POSTS
Hi there,
If the crank seal is leaking, replace the cam seal as well, bearings on timing belt adjuster and any idler pulleys. a good look at all the cooling system hoses, flush and thermostat if you want to.
Mark (mhpautos)
Dec 23, 2007 at 4:44 PM
