1998 Chrysler Concorde Won't Start
STEPHANGAIMAN
1998 Chrysler Concorde, 2.7 liter, 134, 000 miles approx.
While driving the car batter light came on, I turned off all unnecessary things in the car. As I drove it, the light became dim and it eventually it died. As I sat for a while debating my next move, I started the car again. It ran for a very short while (maybe 2 minutes) before doing the same thing again. On my third try, it completely stopped. Now when I turn the key, it clicks. Right before all this happened, I heard a crackling noise coming from the battery side of the car. Could the problem be: alternator, battery, or starter?
Apr 10, 2007 at 11:18 PM
  • 75,988 POSTS
[quote:4c78f55f24="StephanGaiman"]1998 Chrysler Concorde, 2.7 liter, 134, 000 miles approx.
While driving the car batter light came on, I turned off all unnecessary things in the car. As I drove it, the light became dim and it eventually it died. As I sat for a while debating my next move, I started the car again. It ran for a very short while (maybe 2 minutes) before doing the same thing again. On my third try, it completely stopped. Now when I turn the key, it clicks. Right before all this happened, I heard a crackling noise coming from the battery side of the car. Could the problem be: alternator, battery, or starter?[/quote:4c78f55f24]
You need to take out the battery first-could not be taking a charge, the alternator not putting out-do this 2 first, check all connections make sure its cleaned and tight then will go to the starter.
Apr 11, 2007 at 9:49 AM
Suggested Repair
Remove and test the battery first, then test alternator output. Clean and tighten all battery and charging connections before checking the starter.
Conversation Summary
A 1998 Chrysler Concorde with about 134,000 miles showed a battery light, dimmed, and died while driving. It restarted briefly, then died again; the key now only clicks, and a crackling noise was heard near the battery. The expert advised testing the battery and alternator first, cleaning and tightening connections, and checking the starter afterward.
