1998 Chrysler Concorde PCM, BCM. Starting issues
JSCORDOS
  • 1998 CHRYSLER CONCORDE
  • 6 CYL
  • 105,000 MILES
I have had starting issues ever since last with this car It starts, then cuts out - I replaced the Fuel Pump, ECM, CPS, Throttle Position Sensor, Mass Airflow Position Sensor, and the car still does not run. It starts, but then stops almost immediately - It will then not start back up!
The OBD2 codes lead to the BCM being the culprit. I am not too sure by reading about this that this could cause it from starting and/or keeping it running! I truly thought the ECM bought and programmed would repair this, but obviously I was wrong!
Any ideas with this electrical headache I have with this Chrysler?
PLEASE ANYTHING WOULD HELP - Except taking this to the dealer where they told me the BCM would cost $700 LOL WHat a joke when I can get one used for $50.
Thanks a bunch,
John
Monday, August 24th, 2009 AT 12:50 PM
  • 109,885 POSTS
John:
If the codes are leading you to the BCM, that is where I would focus. Chances are there is a problem with it. Get one and try it.
Keep in mind, anything else I say will be a guess because the computer is identifying the problem as the BCM. However, for curiosity sake, when it doesn't start, do you loose spark or fuel?
Thursday, October 1st, 2009 AT 8:15 AM
