1998 Chrysler Concorde V6 Two Wheel Drive Automatic 125000 miles
Have a 98 chrysler concord with a 3.2 that will crank but will not fire. Things I have tried check spark was ok compression was between 150-140 on all cylenders. I pulled a coil to check spark had it can smell fuel and have tried to start using starting fluid still will not fire. I check the signal from the crank sensor was sending one check using my dvom. I pulled the timing cover to check timing cam and crank where lined up correctly. I double checked all the fuses all ok. When car first died it was running fine then just quit I ran the codes with a person code reader code was 1391 crank/cam signal malf. Any suggestions would be appreciated thanks in advance
SPONSORED LINKS
Friday, November 30th, 2007 AT 7:12 PM
