1998 Chrysler Concorde car dies while driving
135,000 MILES • 6 CYL • FWD • AUTOMATIC
TEEMOREZ
I have had this happen quite a few times im driving it doesnt matter whether hwy speeds or local but all of a sudden my engine will die i have power but it will die and it takes a few mins to restart the car. i tried dry gas thinking maybe its bad fuel but it still happens. what can my problem be before i spend tons of money trying to figure it out?
Nov 19, 2009 at 8:04 AM
  • 110,246 POSTS
It could be few things. Has the check engine light ever come on? When this happens, does the engine slowly die or is it like you shut the key? Have you had the fuel pressure tested?
Nov 19, 2009 at 2:35 PM
TEEMOREZ
[quote:e37a943d20="Jacobandnickolas"]It could be few things. Has the check engine light ever come on? When this happens, does the engine slowly die or is it like you shut the key? Have you had the fuel pressure tested?[/quote:e37a943d20]
No check engine light and havent had my fuel pressure tested and yes its like i just shut the key off while im driving. I was gonna get my fuel system cleaned do u think that might help? Or is is a different problem
Nov 19, 2009 at 9:14 PM
