My car died while driving on the highway
193,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
JAMES2015
The car all of a sudden died out of nowhere while driving and now wont start at all it trys to turn over but it does so kind of slow. I got trouble code 1391 so changed my Crank position sensor and it crunkup and then died again after a few minutes. Then I changed Cam sensor with no result. Then the ignition switch with no result. The battery and spark plugs are new. ASD relay is good and the fuel pump is coming on. I HAVE NO CLUE WHAT TO DO NEXT!
Jan 25, 2015 at 3:56 AM
CADIEMAN
  • 3,544 POSTS
your going to need a volt meter and find the wire or wire connector thats going open to the crank position sensor.that is what setting the 1391 and causing the stall. it going open causing the problem. if u put the meter on ohms scale and check the harnesses and connectors for a open circuit u will find it.
Jan 25, 2015 at 5:16 AM
JAMES2015
Thanku I'll do that and reply back
Jan 28, 2015 at 7:19 AM
CADIEMAN
  • 3,544 POSTS
OK
Jan 28, 2015 at 8:04 AM
