1999 Chrysler Concorde Car Keeps Cutting Off
MRJONZES
  • 1999 CHRYSLER CONCORDE
  • 6 CYL
  • FWD
  • 90,000 MILES
To Whom It May Concern,
I have a 1999 Chrysler Concorde and my problem with the vehicle is that it keeps stalling. I was having this problem until I changed my oil and filter. The type of oil that I put in my car was Castro Synthetic 5w-30 and I also put a fuel injector cleaner in as well because of the fact that I was 1000 mile overdue for an oil change.
Sunday, November 2nd, 2008 AT 1:41 PM
  • 109,885 POSTS
Hi:
The oil you are using is very good, so that's not the problem. Also, a thousand miles overdue shouldn't hurt anything.
The fuel injector you used is my question. Did the directions require a cartain amount of gas be in the tank when used? Did you follow the directions? Also, is your check engine light coming on? If so, have you had it scanned for trouble codes?
Wednesday, November 5th, 2008 AT 5:03 PM
