1995 Chrysler Concorde wont start intermitantly
171,000 MILES • 6 CYL • FWD • AUTOMATIC
NORIDE-YET
turn key on, as come on, lights, starter does nothing. batt is fully charged, starter and solonoid work by jumping direct to battery. starter relay tests good outside of car. will start every once in a while. suspect ingnition swich or its wires. What do you think? Help
Sep 6, 2010 at 5:23 AM
ERNEST CLARK
  • 1,730 POSTS
Not sure what you mean by "Exhaust come on"???? But if you're sure the bat and Starter are good, but you get no power when turning the key, then yes, I'd say your ignition switch is bad.
Also check the fuse first, then the connectors and wires. Then look at the ign switch.
Sep 9, 2010 at 10:58 PM
