1995 Chrysler Concorde heater blower runs constant on high
52,000 MILES • 6 CYL • FWD • AUTOMATIC
MWILLY56
Heater blower started running on high blowing hot air constantly. Took a guess and changed a relay but no result. Looked at curciut board behind controls, it is getting power but none of the controls work? car sits alot more than it should thats why the low miles. Is their a control module? Or A blower resistor? Currently we just pulled the 25 amp fuse to stop the blower.
THANKS,
Mike
Oct 10, 2008 at 3:02 PM
ZACKMAN
  • 4,202 POSTS
Blower resistor
Oct 10, 2008 at 7:41 PM
MWILLY56
Thnx for the response, do you know if that would cause the other controls not to work? Is this resistor inside or outside the ductwork?
thnx Mike
Oct 11, 2008 at 12:19 AM
ZACKMAN
  • 4,202 POSTS
It only controls the speed. Nothing else. I am not sure why other controls didn't work. I believe you have to pull the ductwork to see the resistor
Oct 11, 2008 at 5:20 AM
