1995 Chrysler Concorde AC misting from interior vents
1995 CHRYSLER CONCORDE
100,600 MILES • 6 CYL • FWD • AUTOMATIC
SKIMOGULER
When I turn my AC on, there is a visible mist or gas coming from the air vents. If the AC is off, there is no visible gas, if the AC is on and I back the hot-cold dial off of the coldest setting, the mist ceases. There is no distinct odor coming from the gas and it hasn't affected my driving, but I'm curious to figure out what this is.
Jul 10, 2008 at 3:11 AM
DOCFIXIT
  • 18,828 POSTS
What you are seeing is condensation from the moisture the AC is removing. Check to see if drain tube is letting water out on pass. side. Also on humid days if you are operating AC on outside air mode it will draw moisture in and you will see the mist. Run the AC on recirculate mode
Hope this helps
Jul 10, 2008 at 3:25 AM
SKIMOGULER
Thanks. That definitely clears things up.
Jul 11, 2008 at 12:18 AM
