1994 Chrysler Concorde Anti-theft Alarm System
1994 CHRYSLER CONCORDE
CHARLESDPOWELL
I purchased this car in July. It did not come with the keyless entry. The alarm is activating periodically when I open the door with the regular key. Right now I'm stuck with waiting until it stops. Is there a way to deactivate the alarm?
Nov 28, 2007 at 2:33 AM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
[quote:c33d451f0f="charlesdpowell"]I purchased this car in July. It did not come with the keyless entry. The alarm is activating periodically when I open the door with the regular key. Right now I'm stuck with waiting until it stops. Is there a way to deactivate the alarm?[/quote:c33d451f0f]
Try to get a new remote and have it programmed
For the now try to lock and unlock door diver or pass or also trunk using the key it should deactivate the alarm if not you can also try to disconnect the battery turn key to on and reconnect the battery
Good luck
Nov 30, 2007 at 10:50 PM
