Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
Concorde
Security
Computer
1998 Chrysler Concorde ignition security
1998 CHRYSLER CONCORDE
193,000 MILES • 6 CYL • 2WD • AUTOMATIC
ENRIQUEMARIN51
MEMBER
1 POST
problem w/skim module, some times not get signal from the ignition switch, to make it run cam sensor have to be iunpluged
Jul 13, 2010 at 7:22 AM
BLUELIGHTNIN6
Experienced Mechanic
Hello and thanks for donating
Is the check engine light on? If so, what are the codes stored?
If it will not run with the cam sensor plugged up then the cam timing is properly incorrect and will need inspected.
Jul 14, 2010 at 6:34 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
