Heres the issues guys I suspect a faulty water pump but have not checked thermestat or radiator to see if its clogged. I'm thinking water pump because the the coolant boils over when the car is sitting at a red light and the heat blows from warm to cold. Soon as I pull off the temperture hand drops back down to to normal reading, coolant stops overflowing and the heat blows warm again. I no the fans work because they do come on as they should.
I'm looking for advice befor I decide to tackle the water pump due to the fact that its quite a bit of work to replace. One other thing you can't check the water pump for leakage because of the fact that its housed inside the timing cover. O, I also don't believe the heads are blown I'm sure of it.
Feb 18, 2009 at 9:40 PM
