1998 Chrysler Cirrus crankshaft position sensor
1998 CHRYSLER CIRRUS
OMGHELPME
Engine Mechanical problem
1998 Chrysler Cirrus 6 cyl Front Wheel Drive Automatic
how do i remove a stubborn sensor that the bolt area is broken off of. it is still attached to the bellhousing. PLEASE HELP ME
Jan 10, 2009 at 11:45 AM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Is there anything left of the mounting arm? Can you pry up on it gently, with a screwdriver? You might try a pair of vicegrips, gently, see if you can work the sensor side to side, get it loose.
Jan 10, 2009 at 12:06 PM
