1998 Chrysler Cirrus question about crank sensor
DES1RR3
1998 Chrysler Cirrus Two Wheel Drive Automatic 145000 miles
what is a crank sensor?? i was looking at a car and the woman told me it has a couple small rust spots and that the crank sensor was cracked...
Jun 2, 2010 at 1:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The crank sensor (AKA crankshaft position sensor) senses when a notch on the crankshaft goes by and sends a pulse to the car's computer. This tells the computer where the crankshaft is in it rotation so that the computer will fire the spark plug at the correct time. This also allows the computer to change the timing under different conditions such as if gas of too low an octane rating is being used causing predetonation (called knocking) which is sensed by the knock sensor.
Jun 2, 2010 at 5:28 AM
