Electrical problem
1996 Chrysler Cirrus 6 cyl Two Wheel Drive Automatic
Hello, I wrote earlier that is was number 5 but it is number 8 the ign fuel starter fuses that keep blowing everytime we replace them, also replaced battery it cranks good but no starting the car what could be causing this and how do I check to see if the fuel pump relay black fuse is good? thank you
Oct 29, 2009 at 1:10 AM
