Flushing the radiator is a fairly easy job, start by draining the coolant out of the radiator then get a water hose and start the vehicle, turn heat on high let water flow into resvoir until it start flowing out of the radiator where you drained the coolant let this run for about 5 minutes then turn vehicle off put drain plug back in fill resvoir with proper amount of coolant and proper coolant then start vehicle and bleed system
SPONSORED LINKS
Wednesday, March 25th, 2009 AT 7:21 PM
