1990 Chrysler New Yorker AC Vents
BOB1481
  • 5 POSTS
My 1990 Chrysler New Yorker will not blow cold air thru the dash vents no mater where i have the settings,It is a digital control that says off,floor,panel,or windshield,It blows out the floor or windshield when set on air conditioner.I changed out the digital controler and still the same thing,I can not find any vaccume lines off the pod that pulls it from one level to the other and they all sem to be working.HELP PLEASE its a dark car but only got 73.000 miles on it and we use it as a 3rd car,Its a 3.3 liter,auto trans,front wheel drive,4 door.direct port injection. :lol:
Aug 14, 2007 at 6:23 AM
2CARPRO JACK
  • 11,533 POSTS
Have you checked the source vacuum at the brake booster? that is usually where they tap into it for Chryslers
Dec 6, 2007 at 2:17 AM
BOB1481
  • 5 POSTS
Yes have checked the air at the brake booster,17 1/2 in vac at idle and at cly that the hose goes to under the dash.Same vac there.
TKS
Bob
Dec 6, 2007 at 2:55 AM
2CARPRO JACK
  • 11,533 POSTS
Need to tear into it a little and find the door that controls the levels and see if the vacuum actuator is good.
Dec 6, 2007 at 3:12 AM
Suggested Repair
Source vacuum at the brake booster and under the dash is already confirmed good, and the digital controller was replaced. Access the mode door that directs airflow and test whether its vacuum actuator is working.
Conversation Summary
A 1990 Chrysler New Yorker with digital climate controls blows from the floor or windshield instead of the dash vents on A/C, regardless of setting. The owner replaced the controller and confirmed about 17.5 inches of vacuum at the brake booster and under the dash. The expert advised opening the system to locate the mode door and check its vacuum actuator.
