2002 Chrysler 300M Dies After Jump
96BLUESTANG
  • 10 POSTS
i have a 2002 chrysler 300M, engine will not run unless the battery is jump started with another car. When you take off jumper cables the car will act like it wants to go off then slowly it dies off! then you hear a wistle sound. A code is given P1604 : Loss of IPC Serial Data. How do we get this fixed?
Oct 28, 2007 at 1:29 PM
BLACKOP555
  • 10,386 POSTS
first i would try a new battery and alternator. that the car shutting off when it is removed tells me thers not enough juicei n the battery for it to continue running and also the alternator is not producing enough to charge the battery!
Oct 28, 2007 at 1:58 PM
BMRFIXIT
  • 19,053 POSTS
[quote:eba3bc91b2="96bluestang"]i have a 2002 chrysler 300M, engine will not run unless the battery is jump started with another car. When you take off jumper cables the car will act like it wants to go off then slowly it dies off! then you hear a wistle sound. A code is given P1604 : Loss of IPC Serial Data. How do we get this fixed?[/quote:eba3bc91b2] first check the charging system
make sure it charging and test the battery make sure it good and fully charged
basic 1st than codes
you may need an alternator
or your bcm no good
check the alternator
good luck
Oct 28, 2007 at 2:01 PM
Suggested Repair
Test the battery and charging system first and confirm the battery is good and fully charged. Replace the battery and/or alternator if the system is not charging. If charging checks out, investigate the BCM in relation to code P1604.
Conversation Summary
A 2002 Chrysler 300M will not keep running unless jump-started and dies after the jumper cables are removed, with a whistle sound and code P1604 (loss of IPC serial data). Experts recommend checking the battery and charging system first, noting a weak battery or failed alternator, and considering the BCM if charging is confirmed good.
