2000 Chrysler 300M Won't Start After New Key
Hey heiterd,
If its installed with an immobilizer:
1. Is there a "security light" on or flashing continuously?
2. If not I recommend calling Chrysler back for the reset procedure.
3. If it is you may need to leave the key on (don't try to start it) for 5+ minutes to clear it. Additionally, you also may need to hook up a battery charger to keep the battery from going low during this time. Then turn the key off and try to start the vehicle.
4. If it won't start, then I recommend it go to chrysler.
Chris
Suggested Repair
Check whether the security light is on or flashing. If it is, leave the key on without cranking for more than five minutes, using a battery charger if needed, then turn the key off and try to start. If the light is not on, call Chrysler for the immobilizer reset procedure. If the car still will not start, have Chrysler diagnose it.
Conversation Summary
The owner of a 2000 Chrysler 300M lost the key, had a locksmith cut a transponder key, and successfully programmed it with Chrysler codes, but the car still will not start after battery disconnects. The expert asks whether the security light is on or flashing, suggests a key-on wait of more than five minutes with a charger if the light is active, and otherwise recommends contacting Chrysler for the reset or taking the car in.
