Won't shift into gear
APRIL TAYLOR SEIF
  • 23 POSTS
Put tranny fluid in but ended up all over the ground. Will check the other advice. Will let you know thank you
Monday, December 9th, 2019 AT 11:27 AM (Merged)
HMAC300
  • 48,601 POSTS
First fix the trans leak. Whenever engines are replaced by some times the torque converter slides forward then is not put back in then engine is bolted up and started which the torque converter slides out of oil pump then destroys it on start up of different engine if converter wasn't put back in towards trans then this is what happened.
APRIL TAYLOR SEIF
  • 23 POSTS
So if this happened can the torque converter be replaced only or does the whole tranny need replaced
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,536 POSTS
If the torque converter was not in all the way and the transmission was bolted up then at least the front pump of the transmission will need to be replaced. Sorry, its a hard lesson and most mechanics learn it the hard way so don't feel bad. I speak from experience :)
See if you can get a used transmission.
2CP-ARCHIVES
  • 4,540 POSTS
  • 2003 CHRYSLER 300
  • 160 MILES
Sometime the vehicle will not change from 1st gear to 2nd gear and if I stop, turn the vehicle off and drive off again, the car will change gears as it should. Somtimes iam driving along and the vehicle goes into this want change gears mode.
CARADIODOC
  • 34,396 POSTS
Actually, second gear is the default for "limp mode". That allows you to drive slowly to a repair shop without needing a tow truck. As a general rule, if it goes to second gear as soon as you shift into "drive", it is a sensor or other electrical issue. If it starts out in first gear like normal, then bangs to second gear during or right after an up-shift, it is usually due to slippage in one of the clutch packs. That happens more commonly on high-mileage vehicles. Years ago we had a year or two of warning because we could feel the shifts become sloppy or soft. With your computer-controlled transmission, the computer knows how much wear has taken place in the clutch plates and it modifies shift timing to overcome that wear and provide continued crisp, solid shifts, ... Until the day comes when it can't update those shift schedules enough. That's when the slippage takes place with no warning and it goes to limp mode. The clutches don't actually wear out any faster. It's just that you don't having the warning it's happening.
Your mechanic will start by reading the stored diagnostic fault codes. That will tell him the reason it went to limp mode. He can also read the "clutch volume index", (CVI). That is a set of four numbers corresponding to the volume of fluid it takes to apply each clutch pack. An experienced mechanic will know how much life is left in each clutch based on those numbers.
APRIL TAYLOR SEIF
  • 23 POSTS
Before putting engine in we mounted torque convert to the engine. So what could it be
HMAC300
  • 48,601 POSTS
Probably what ken just replied, the torque converter should have been put in trans instead of engine soyou probably damaged pump to where you have nothing moving in trans.
APRIL TAYLOR SEIF
  • 23 POSTS
Ok ty. We are going Friday to get tranny. Is there anything special I need to know before putting all of it back together. We are taking engine and tranny out in one piece and putting back in one piece.
HMAC300
  • 48,601 POSTS
Make sure the converter is in all the way you'll know then bolt trans to engine after engine is installed bolt up converter. Converter should be about an inch away from engine at least after bolting up. Make sure the electrical connections will work as well.
APRIL TAYLOR SEIF
  • 23 POSTS
Is there any interchangeable transmissions for this model. 2005 chrysler 300c 3.5 v6 rw drive
HMAC300
  • 48,601 POSTS
Check with a junk yard they know better than us.
CURIOUSLIL12000
  • 2001 CHRYSLER 300
  • 6 CYL
  • 180,000 MILES
Yesterday my 300 wouldn't change past first gear and rev to 3 grand at 5o kms I tried using the auto shift but all the lights on the gears came on and nothing happened.
Park, neutral, and reverse all work fine but won't shift gears when driving.
I hope this is an easy fix I only bought the car a year ago and love driving it.
Please help!
CARADIODOC
  • 34,396 POSTS
Sticking in second gear is "limp mode" that allows you to drive it slowly to a repair shop without needing a tow truck; definitely not at highway speed. In general, when it starts out in second gear and all the shift indicator lights are on, it's usually a sensor or other electrical problem. If it bangs back down to second gear during or right after an up-shift, it's more likely to be slippage in one of the clutch packs. Either way, there will be at least one diagnostic fault code stored in the Transmission Computer. Having those codes read is the place to start. You'll need a mechanic with a scanner that can access the Electronic Automatic Transmission Controller (EATX).
STEVECOOPER2011
  • 1999 CHRYSLER 300
  • 6 CYL
  • 100,400 MILES
I have a 99 Chrysler 300m that won't shift out of 1st gear even with the auto stick. I have replaced the input and output transmission sensors and still no fix. I also did a transmission filter kit and still no change. My speedo works and there are no transmission codes present. What's going on can it be the TCM?
Scan the TCM for code/s could be a sticking shifting solenoid/s, you could also have it pressure tested to find out more-
STEVECOOPER2011
There was no codes present on that which is weird. Also when I pulled the TCM shutdown relay there was absolutely no change to it. Still drove the same no shifting into 2nd. Do you think that the TCM has an issue or is stuck on off mode?
