2005 Chrysler 300 Taillights
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
STONEIT
My car is blowing park light fuses, which included my taillights. The fuse blows after driving for appx. 2 miles. The fuses will not blow if the car is park and the lights are on. The fuses only blows while driving with the lights on. Please guide me to a solution to this problem.
Feb 19, 2010 at 1:17 PM
HMAC300
  • 48,601 POSTS
if the car has been in an accident check on the driver's side usually for damage to the wires. they are shorting out and blowing hte fuses as you move. You may have panels in th trunk to remmove and look at the wiring. If you can't find it take it to a pro he will, as he has access to things you don't. As there may be a techinical bulletin out.
Mar 11, 2010 at 12:18 PM
