I had the battery check and was told the battery is fine. When a load was placed on the battery, it only showed a 45% charge. The alternator was checked out as well and I was told it was fine as well. I was advised to check the wiring from the alternator to the battery, there may be a short or a bad ground. What else could be causing the battery to only receive a 45% charge? Thanks!
Oct 29, 2010 at 4:09 AM
