The car shutters when taking tight turns after driving it for over 100 miles. What could cause this?
Feb 23, 2009 at 7:56 AM
✓Experienced Mechanic
This could be caused by the 4wd. Make sure the front differential oil is clean. also, if it has limited slip, make sure to use the additive when serviced, otherwise the clutches won't release properly and could cause this problem.
Let me know whatyou find.
Mar 15, 2009 at 3:50 PM
