1999 Chrysler 300 front end
1999 CHRYSLER 300
42,000 MILES • 6 CYL • 2WD • AUTOMATIC
CREVY59
While avoiding another driver I hit a curb and blew out the front right tire, after installing the spare tire I drove it home approx. 8 miles. while driving the front end began to shake and continued to get worse until I was less that 1/4 mile from home when the left side tire blew. I haven't driven it since but I am replacing the two tires today and want to know if a front end alignment would fix the problem or has there been damage to something else. I have removed both front tire and inspected the tie rods, ars, and other attaching hardware that I could see and found no visible damage such as cracks, breaks, bending or anything hang loose.
Jun 1, 2010 at 4:14 AM
BLACKOP555
  • 10,386 POSTS
id bet checking for a bent axle shaft or a destroyed wheel bearing/hub assembly also. an alignment if all parts are good should fix it up.
Jun 2, 2010 at 3:10 AM
