Friday, October 2nd, 2009 AT 12:42 AM
What could cause a car to run find. Then it will just cut off, when the car cuts off and you try to restart the car the accelerator want press down you may have to keep trying several times before you can get the accelerator to press down, but once it presses down the car will start, also sometimes you maybe able to drive for 2 or 3 days before it will cut off on you. Then other days it will cut off on you several times a day.
