Choke stuck on
90,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
SHELD
Last week the choke wouldn't come on . Now it is stuck on i think it is idling at 1,200 rpm's.
Jan 3, 2020 at 11:27 PM
JIS001
  • 3,412 POSTS
I do not see any vehicle here in the USA market for your model year. Since it is 2005 there is no choke. I would recommend you disconnect the battery and remove the throttle body and clean it out to see if it resolves the issue. Here is a link on how to clean the throttle body:
After you clean it out, reconnect the battery. If you still have an issue with the high idle then I would suspect a faulty engine coolant temperature sensor.
Jan 4, 2020 at 5:13 PM
